Fuel Pump runs continuously
TNSHEETS
  • 1996 FORD RANGER
Computer problem
1996 Ford Ranger 4 cylinder.
The fuel pump runs continuously with the key on but will shut off when I turn the key off. It also will not start. What could the problem be? What should I look at?
Monday, June 21st, 2010 AT 9:21 AM
RACEFAN966
  • 5,029 POSTS
Okay, first if you would pull a spark plug wire off of one of the spark plugs and put a Philips screwdriver in the end and put it near metal (like the valve cover) and crank it over and see if there is spark. Let me know what you find, and we will go from there.
Tuesday, June 22nd, 2010 AT 10:50 AM
