HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Ranger
Fuel System
Fuel Pump
1994 Ford Ranger fuel pump
JKRUEGER
MEMBER
1994 FORD RANGER
4 CYL
2WD
MANUAL
150,000 MILES
Only getting 1or 2 volts thru the harness to the fuel pump. Fuel pump runs when I jump 12 volts to it.
Sunday, February 21st, 2010 AT 9:44 PM
BLUELIGHTNIN6
MECHANIC
Check fuel pump relay. If OK check inertia switch, located behind right side of dash, below glove box.
Sunday, February 21st, 2010 AT 9:48 PM
MECHANIC
Check and test the fuel pump relay and inertia fuel cut off switch
Sunday, February 21st, 2010 AT 9:56 PM
Please
login
or
register
to post a reply.
Related Fuel System Fuel Pump Content
1994 Ford Ranger Fuel Pump
When I Turn The Key On The Fuel Pump Keeps Running On A Cold Start And The Truck Will Not Start If I Leave The Key On For A Few Minutes...
Asked by
CasperPark
1 ANSWER
1994
FORD RANGER
VIDEO
Fuel Pump Replacement Ford
Instructional repair video
GUIDE
Fuel Pump
Fuel Pump Features
1994 Ford Ranger Fuel Pump Or Something Else?
Cold Start, Engine Has To Crank For 10-15 Seconds Before It Will Start After It Has Warmed Up It Will Start Immediately, If You Let It Set...
Asked by
94stranger
1 ANSWER
1994
FORD RANGER
1994 Ford Ranger Cold Starting
Engine Performance Problem 1994 Ford Ranger 6 Cyl Two Wheel Drive Manual N/a Miles When I Start My Truck After Its Been Sitting All...
Asked by
inkaddict2316
1994
FORD RANGER
I Am Not Getting Fire To The Fuel Pump But If You Push...
I Am Not Getting Fire To The Fuel Pump But If You Push Start It It Turns On
Asked by
Anonymous
1 ANSWER
1994
FORD RANGER
1999 Ford Ranger In Tank Fuel Pump Components
Electrical Problem 1999 Ford Ranger 4 Cyl Two Wheel Drive Manual What Is The Small Electrical Part Called On The Top Of The In Tank...
Asked by
omontoya361
1 ANSWER
1999
FORD RANGER
VIEW MORE
How to Replace Fuel Pump
Fuel Pump Replacement Toyota
