Check your fuel pump relay and the fuel pump shut off, it is located on the firewall under the driverside dash.
SPONSORED LINKS
Friday, January 11th, 2008 AT 7:32 PM
JOHNAMOSHALL
MEMBER
Yes, we have tried both and to no avail. Thanks for the feedback, that was good advice.
Saturday, January 12th, 2008 AT 5:07 AM
BLACKOP555
MECHANIC
Do you have 12v at the fuel shut off switch? Is 12v leaving it?
Saturday, January 12th, 2008 AT 9:03 AM
JOHNAMOSHALL
MEMBER
There was no power leaving the fuel shut off switch. Where is the fuel relay located? Is it located in the distributer box under the hood on the driver side? If so, I have checked that already and all the relays are working.
Saturday, January 12th, 2008 AT 10:11 AM
BLACKOP555
MECHANIC
The fuel pump relay on a 1995 Ford Explorer is in the power distribution
box, in the engine compartment, driver's side near the firewall.
SPONSORED LINKS
Saturday, January 12th, 2008 AT 7:10 PM
JOHNAMOSHALL
MEMBER
Okay, then I checked them and they are all working. Any other suggestions?
Saturday, January 12th, 2008 AT 7:41 PM
BLACKOP555
MECHANIC
You have voltage going to and coming out of the relay then? But none going to the fuel pump shut off, if that is the case you need to check your wires from the relay to the shut off switch.
