1999 Ford Ranger lossing clucth fluid
LA GANZA
  • 44 POSTS
Transmission problem
1999 Ford Ranger 6 cyl Four Wheel Drive Manual
I have 99 ranger 5 speed v6 is loossing clucth fluid could be the sleave cylinder ,master cylinder?
Jan 22, 2009 at 12:21 PM
DAVE H
  • 13,383 POSTS
you will have to locate where the actual leak is coming from before we can assist further ?
The hydraulic clutch control system consists of the hydraulic master cylinder, slave cylinder, reservoir, clutch pedal position switch, and connecting hydraulic lines. The clutch disc and pressure plate are single-disc type. The clutch release bearing or bearing arm is activated by hydraulic pressure. The clutch linkage or pedal position requires no adjustments.
Jan 22, 2009 at 12:55 PM
