1999 Ford Ranger Gear Ratio
TRAVIS09
  • 1999 FORD RANGER
  • 6 CYL
  • 4WD
  • MANUAL
  • 126,000 MILES
I need the gear ratio for the front end and the rear end
Saturday, February 21st, 2009 AT 4:01 PM
  • 110,055 POSTS
Hi:
different ratios were available so it's hard for me to say. If you take the vin number to a dealer, they should be able to tell you. Also, if you count the number of revolutions of the pinion gear compared to the ring gear, you can figure it out. Finally, the front and rear must be the same ratio on a 4wd.
I hope this helps.
Saturday, February 21st, 2009 AT 8:45 PM
D.O.C63
Www. Therangerstation. Com they have the chart that shows how to determine the gear ratio in your truck. Hope that helps
Wednesday, March 11th, 2009 AT 2:57 PM
