1999 Ford Ranger battery gauge
100,500 MILES • 6 CYL • 4WD • AUTOMATIC
KARATEMAN
when i am coming to a stop my battery gauge goes way down and the lights dim and the idle drops way down but then it will come back up when i hit the gas pedal
Jan 5, 2008 at 2:26 AM
ZUE
  • 76 POSTS
If you have not done so already, do the basics like check the belt tension to the alternator. and water level in the battery. Take your car to you local autostore and have them run a free diagnostic of the electrical system to see if a weak alternator is your problem.
Jan 5, 2008 at 3:14 AM
KARATEMAN
ty for ur timely answer but i already had the battery and alternator checked and they said they were fine ny other possibilies it could be?
Jan 5, 2008 at 3:24 AM
ZUE
  • 76 POSTS
Did you fins a solution to your earlier problem?
Dec 4, 2010 at 11:00 PM
