1999 Ford Ranger ball joints
ROYBOY37
  • 1999 FORD RANGER
  • 6 CYL
  • 108,000 MILES
How do you replace the upper ball joint on the left side upper support arm?
Saturday, October 18th, 2008 AT 2:42 PM
JNOVACK
  • 723 POSTS
The ball joints are arranged such that if the upper ball joint is to be removed, the lower ball joint must be removed first. Conversely, the upper ball joint must be installed first, before the lower ball joint. Failure to install the upper ball joint before the lower, will result in a lack of clearance for the installation tool.
1-Remove the steering knuckle.
2-Place knuckle in vise and remove snapring from bottom ball joint socket if so equipped.
3-using ball joint remover on the lower ball joint.
4-Turn forcing screw clockwise until the lower ball joint is removed from the steering knuckle.
5-Repeat the previous steps for the upper ball joint.
Always remove the lower ball joint first.
To install:
6-Clean the steering knuckle bore and insert lower ball joint in knuckle as straight as possible. The lower ball joint doesn't have a cotter pin hole in the stud.
7-using ball joint remover install the upper ball joint.
8-Turn the forcing screw clockwise until the upper ball joint is firmly seated.
10-If the ball joint cannot be installed to the proper depth, realignment of the receiver cup and ball joint installer will be necessary.
Repeat the previous steps for the upper ball joint. Install the snapring on the lower ball joint.
Install the steering knuckle.
Saturday, October 18th, 2008 AT 3:24 PM
