There are 4 easy accessible spark plugs on the engines right side, but on the left there 4 more hidden under the intake. You will have to remove the intake to get to them. Watch your hoses and vacuum lines during the removal process. Replace your intake gasket, and torque to 23 foot Lbs. Also conceder removing some coolant first... Makes for a smaller mess later. It's a relatively easy procedure to do
SPONSORED LINKS
Wednesday, November 5th, 2008 AT 10:00 AM
