1998 Ford Ranger starting
WYANS830
  • 1998 FORD RANGER
  • 4 CYL
  • 100,000 MILES
I was having trouble shifting car out of park when strarted now I can shift but truck will not turn over have plenty of battery
Monday, January 4th, 2010 AT 6:17 AM
RACEFAN966
  • 5,029 POSTS
Tell me what do you mean won't start? Does it not turn over at all or does it crank over and just not start?
Monday, January 4th, 2010 AT 11:50 AM
WYANS830
Does not turn over at all
Monday, January 4th, 2010 AT 12:48 PM
RACEFAN966
  • 5,029 POSTS
OK first I would like you check Maxi fuse number 5 it is a 50 amp(in under hood fuse box). If the fuse is good then I need you find the starter relay in the under hood fuse box. Check the yellow wire going to it make sure there is power there. If there is power at the yellow wire to the relay then you need to see if there is power coming from the relay when you turn the key to start possition, check the yellow wire with the light blue stripe or check the wire at the starter solinoid term S wire is same color.
Monday, January 4th, 2010 AT 1:00 PM
