1998 Ford Ranger instrument panel removal
1998 FORD RANGER
251,000 MILES • 6 CYL • 2WD • AUTOMATIC
FROGGER2008
I Have Been Trying For 2 Days To Change The Heater Core By Using A (Very Vague) Haynes Manual
I Simply Cannot Get The Instrument Panel Out Of The Pick-up.If I Had A Detailed Diagram of how to get the instrument panel out, i believe i could finally get this thing changed & put back together.It Simply Will Not Come Out. I Can Tell That There Are Still Some Bolts Or Nuts That I Have Not Taken Out
Jan 6, 2008 at 12:50 AM
2CARPRO JACK
  • 11,533 POSTS
Our software doesnt have any one picture for removal of the instrument panel (dash). Is th esteering column out of the truck? Disable air-bag system. Evacuate a/c, drain all coolant. There is 5 bolts across the top of the dash and 1 on th efar right of th edash and 2 on the far left. The entire bulkhead wiring connector needs to be freed up as well
Jan 9, 2008 at 9:31 AM
