1998 Ford Ranger Alternator bad
RR3PFS
  • 1998 FORD RANGER
  • 4 CYL
  • 47,000 MILES
My Ford Ranger had the battery light on and the voltage meter show low charge. I took it to Sears because that is where I got the battery. They said the battery was bad and replaced it, new battery. When they tested to see if that fixed it, everything was the same. They said I had a bad alternator was bad. I drove it home because I can change the part.
Went to AutoZone Got a new alternator and installed it. Same problem as before, no change. I have checked all of the conections and wires and found no problems. SO, I took the alternatior back to AZ and they gave me a new one. Came home, installed it. Same result, Battery light on and volt meter on the low side. What am I missing. I so like PNP auto parts.
Friday, July 2nd, 2010 AT 9:21 PM
SATURNTECH9
  • 30,869 POSTS
I emailed you a trouble tree so you can figure out why it's not charging. Please post all question's and finding's to this posted question so other user can use your problem to fix there truck.
Friday, July 2nd, 2010 AT 9:53 PM
RR3PFS
Saturntech9,
Thanks for your fast response. I will check my email and get back to you as soon as I find something out.
Saturday, July 3rd, 2010 AT 2:13 PM
