I purchased my truck in February and had new brake pads put on, and had a rotor and brake hose replaced on the passenger side. It has always made a clunking noise in the front when I use the brake and the brakes kind of pump back at you. Now I have a rhythmic clunk when I am driving. I have also just recently been hearing what I can only describe as and aircraft engine winding up when I press on the gas peddle, and I am also hearing another noise on top of that that gets worse when I press on the gas peddle. This noise sounds more like something spinning. Can you please give me some ideas as to what the issue is? I dont know if I have described it well enough, but if there is anyone out there that can help I would appreciate it.
Thanks
SPONSORED LINKS
Friday, August 7th, 2009 AT 2:08 PM
