1998 Ford Ranger
BANGIN24S
  • 1998 FORD RANGER
  • 4 CYL
  • 126,000 MILES
How do I fix my oil gauge in my 98' ford ranger
Monday, December 22nd, 2008 AT 7:40 PM
DAVE H
  • 13,384 POSTS
OIL PRESSURE GAUGE TEST
Disconnect oil pressure sensor harness connector. Connect instrument gauge system tester to oil pressure sensor harness connector wire. Turn ignition on. Set tester to infinity. Oil pressure gauge should read below "L" (low). Short oil pressure sensor harness connector wire to ground. Oil pressure gauge should read above mid scale. If oil pressure gauge functions as specified, replace oil pressure switch. If oil pressure gauge does not function as specified, replace oil pressure gauge.
Monday, March 29th, 2021 AT 7:45 PM
