1997 Ford Ranger no get up and go
NOGALES
  • 1997 FORD RANGER
  • 4 CYL
  • MANUAL
  • 211,058 MILES
Put new plugs and plug wires on. Truck still runs real sluggish any ideas?
Monday, July 5th, 2010 AT 3:37 PM
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard
Monday, July 5th, 2010 AT 8:10 PM
