Check engine light on?
JDL
  • 16,098 POSTS
Hello, there should be a horn relay and horn maxi fuse in fuse box under the hood, check voltage to those circuits. The problem is usually the horn pad or wiring in the column. If you use a jumper on the terminals for the load side of horn relay, the horn should honk.
The codes don't tell you what to replace, just that the computer thinks there is a problem on that circuit. As far as the 02 sensor code, you usually try to make the system go rich or lean, then see if the sensor reacts, if it does, the sensor is probably ok. Maybe another issue causing the system to go rich or lean? That wasn't much help, was it?
Friday, November 27th, 2020 AT 10:30 AM (Merged)
PHTM409
  • 1997 FORD RANGER
My wife to take the truck to get a ca. Smog test. She noticed the service engine light did not come on when she first turned the key on. Before starting. Any ideas where start to trouble shhot this one fuses all look good. Maybe a bulb? Or is a sensor to test. Ca. No light at start up is automatic fail. Any ideas would be great.
CHEVY350GUY
  • 109 POSTS
It is probably the bulb if all other lights work.
PHTM409
Thanks. Im looking it up now
MLMS001
  • 1997 FORD RANGER
  • 6 CYL
  • 4WD
  • 116,000 MILES
Replaceing thermostat on 97 ford ranger 4.0
engine light on.
BMRFIXIT
  • 19,053 POSTS
What do you have codes?
MLMS001
I had a diaignostic check it showed the thermostat was bad. I need to know how to replace it.
Thanks
Leonard Smith
BMRFIXIT
  • 19,053 POSTS
Removal
CAUTION:Do not pry on water thermostat (8575) to remove.
Drain the cooling system so that the coolant level is below the water thermostat as described in COOLING SYSTEM BLEEDING.
Disconnect the heater return hose at thermostat housing located on the left front lower side of the engine (6007) (2.3L only). Disconnect engine coolant temperature sensor (ECT sensor) (12A648) connector (2.3L only).
Remove upper radiator hose (8260).
Remove the coolant outlet housing retaining bolts.
Pull the elbow away from the cylinder head (6049) or manifold sufficiently to provide access to the water thermostat. Remove the water thermostat and gasket.
HANNAMOUNCE
  • 1997 FORD RANGER
  • 6 CYL
  • MANUAL
  • 65,000 MILES
I have been driving more than normal and my check engine light came on today. The engine is okay on all fluid levels and is not overheating. Is this most likely an O2 sensor or could it be anything? Is it safe to drive or do I have to get it checked right away?
  • 31,937 POSTS
Hi there,
This light is an indication that there is a problem, so I would not ignore it, get a scan done and report back your findings for more assistance.
Mark (mhpautos)
1SANDIEGAN
  • 1995 FORD RANGER
  • 4 CYL
  • MANUAL
  • 174,000 MILES
I just bought this truck for work but I am having a problem figuring out this check engine light
The engine runs good, slightly rough idle and I don't think it is getting the best mileage. I also think it is quite low on power. I cleaned the MAF thinking this may be the cause but did not seem to change anything. I cleaned it with an electrical cleaner that does not leave any residue.
Also, once I reset the MIL code, it seems to reappear after about 50 miles but it will be quicker if I'm using my a/c, which cycles too much (probably low on refrigerant)
I'm not one to throw a lot of money at a vehicle with this many miles so hopefully you can help me. I don't like to replace parts until I'm sure they are bad.
The code I'm pulling is P0712 - System too rich (Bank 1)
Here is the info I got from the scanner:
I/M monitors:
Misfire Mon: OK
Fuel Sys Mon: OK
Comp Component: OK
Catalyst Mon: INC
HTD Catalyst: N/A
Evap System Mon: N/A
Sec Air System: N/A
A/C Refrig Mon: OK
Oxygen Sens Mon: INC
Oxygen Sens HTR: INC
EGR System Mon: OK
Freeze Dat
Engine RPM: 1576
Load Value: 78.0%
Coolant Temp: 188f
Short Term Fuel Trim 1: -5.1%
Long Term Fuel Trim 1: -16.1%
Short Term Fuel Trim 2: -5.1%
Long Term Fuel Trim 2: -16.1%
Short Term Fuel Trim 3: 53.9%
Long Term Fuel Trim 3: 47.6%
Short Term Fuel Trim 4: 59.3%
Speed: 32mph
Fuel System 1: CLSD
Fuel System 2: N/A
Any help will be greatly appreciated!
Friday, November 27th, 2020 AT 10:31 AM (Merged)
P0172
Possible causes include a bad O2 sensor, excessive fuel pressure (bad fuel pressure regulator or plugged return line), leaky fuel injectors, dirty air filter or restricted air inlet, or a defective coolant sensor that prevents the engine management system from going into closed loop mode
1SANDIEGAN
I removed the vacuum hose to see if there was any fuel in it but it was dry.
Also, what do you think would be the most likely cause? I looked at the O2 sensors and they actually look pretty new.
Thanks for your help!
You need a scantool to finger the oxygen sensor/s by viewing the switching activity/fuel trimmings-Your fuel mix is on the rich side-
  • 1995 FORD RANGER
  • 6 CYL
  • MANUAL
  • 173,000 MILES
My 95 ranger starts and goes dead starts and goes dead does this for a while and finally cranks trucks runs great thought it was a fuel problem replaced filter and checked fuel pressure everything is fine seems like a sensor problem or computer but my check engine light is not on.
  • 110,055 POSTS
When was the last tune up? Also, with that many miles, it could be starting to get low on compression. You may want to check that. Finally, I understand the fuel pressure is good, but does it drop off quick when you turn the key off?
