1996 Ford Ranger Odometer stopped working
1996 FORD RANGER
16,500 MILES • 4 CYL • 2WD • MANUAL
NATNAT
I replaced the sensor on the rear differential, however the problem still exists. The odometer trip and actual mileage work for a tenth of a mile then stops again. What else should I troubleshoot.
Jul 1, 2008 at 6:33 PM
AIRSOFTSOLDRECN9
  • 348 POSTS
Is it a mechanical or electrical sensor? If it is mechanical you can see if the cable inside rotates if you push the car backward or forward. If it is electrical then you might want to check for a broken circuit using a voltmeter. Test for proper voltage on the instrument panel circuit board. Most likely there is a problem with the internals of the guage and it just needs to be repaired or replaced.
Jul 1, 2008 at 7:11 PM
2CARPRO JACK
  • 11,533 POSTS
Does the speedo work? If so it is a problem in the cluster, if not it is related to the speedo not woking, does it have a cable or electronic VSS?
Jul 3, 2008 at 12:35 AM
