1996 Ford Ranger 1996 Ranger Overdrive
1996 FORD RANGER
107,000 MILES • 4 CYL • 2WD • AUTOMATIC
1996RANGERRON
Hello, I recently purchased a 1996 Ranger 4cyl automatic 107K miles. It was a fleet vehicle here on post and never left the post. Top speed on post is 50mph. This truck runs great a low speed but when you get it on the highway the O/D off light flashes. Code scan shows stuck O/D solenoid. When you shut the vehicle off and restart it goes back to normal. Transmission seems to chage gears erratically at no special interval once over 50 mph.. Any help is appreciated as I would like this to be my Daughters 16th Bday gift.
Jun 5, 2009 at 1:50 PM
BILLYMAC
  • 2,204 POSTS
hi this could be something as simple as a bad od switch or could be the od sol inside the trans .
Jun 6, 2009 at 1:28 AM
1996RANGERRON
Is there anyway for me to see what's wrong and fix
Jun 6, 2009 at 3:29 AM
BILLYMAC
  • 2,204 POSTS
hi. if you had it scanned, and the code was for a stuck sol. then this is the prob.
now to fix this prob you will need too remove trans pan and you will see a lot of parts the sol is under one of these valve body,s. these are very complicated and precise torque must be followed.
or your trans will not work at all. buy a manual before you start this project... billymac
Jun 7, 2009 at 1:36 AM
