HOW DO YOU TAKE OF THE DRIVER'S {LEFT} WINDOW REGULATOR?
Dec 22, 2007 at 7:53 AM
MERLIN2021
✓Experienced Mechanic
Some have rivets that must be drilled out, others there are 3 small dimples on the lower part of the door, they must be drilled large enough to fit the 8 mm socket thru to unscrew the bolts....
