Engine will not start?
MAVERICK09
  • 1994 FORD RANGER
Engine Mechanical problem
1994 Ford Ranger 6 cyl Two Wheel Drive Automatic
It will not start engine will crank. I hold the key on start engine turns over but will not fire, had the computer and dist. Replaced about 2 years ago, is doing the same it did then, could the computer be at fault again, it is geting gas
Saturday, February 6th, 2010 AT 9:18 PM
When you turn the key to the on position without cranking the engine over can you hear the fuel pump run in the tank for 5 seconds?
Tuesday, March 2nd, 2021 AT 6:51 PM
