Truck will not go into gear with engine on
DAVE86
  • 1994 FORD RANGER
  • 4 CYL
  • MANUAL
  • 115,000 MILES
The truck will not go into gear with engine on. It will grind if you try and put it in reverse and just will not move into any other gear (no grinding). With the engine off though, it will cycle thru all gears just fine.
I am not a mechanic so any info will be helpful.
Dave
Thursday, October 29th, 2009 AT 7:10 AM
  • 109,885 POSTS
First, open the hood and make sure the clutch reservoir is full. If it is, chances are either the slave cylender or the pressure plate is bad.
Let me know what you find.
Monday, May 3rd, 2021 AT 2:21 PM
DAVE86
I have looked under the hood, cause that is what I thought, I cannot find any res. For any kind of fluid except brake, coolant, etc. The normal stuff. I did go under and take a look at the transmission itself, I saw what I thought was a fill cap and another that I assume it the drain plug. Any other comments. Thanks for your help.
Dave
  • 109,885 POSTS
It's there. Check on the driver's side of the firewall (under the hood). It's only about 2 inches high and 2 inches in diameter.
DAVE86
Thank you so much for your help. I will look again tonight after work and let you know what I find. Again, this is great and glad I found this place.
Thanks again,
Dave
