Not going into gear, while the truck is running
DEMATTEO
  • 1990 FORD RANGER
  • 6 CYL
  • MANUAL
  • 96,000 MILES
My ranger is not going into gear, while the truck is running. When I shut it off it will go into gear. I checked the clutch fluid and it was a little low. I put fluid in it and pumped the clutch pedal, still nothing. It happened randomley while I was driving it.
Wednesday, October 14th, 2009 AT 2:30 PM
  • 109,885 POSTS
If it shifts through the gears with the engine off, the trans is most likely fine. Have you ever serviced it? Also, if the problem is when it is running, does it seem to get worse the hotter the engine gets?
Monday, May 3rd, 2021 AT 2:21 PM
DEMATTEO
I have not had it serviced and it does not matter if the engine is cold or hot. It did after about 5 mins of me drivin it.
  • 109,885 POSTS
Chances are the clutch needs replaced, 96k isnt really that much on a clutch... you could also have a hydraulic issue
Here are some guides to read, they will help you figure out whats wrong
https://www.2carpros.com/articles/clutch-doesnt-work-sometimes-or-not-at-all
https://www.2carpros.com/articles/clutch-symptoms
https://www.2carpros.com/articles/how-to-replace-a-clutch
