1994 Ford Ranger stalls
JHAUGH
  • 1994 FORD RANGER
Engine Performance problem
1994 Ford Ranger 4 cyl Two Wheel Drive Automatic
Had a crash into a curb strong enough to smash pass side wheel. Got that repaired but can't step on gas. I can idle, in drive; but as soon as I step on gas, it stalls out. I checked the inertia cut off switch in cab and it is pressed down. Vehichle worked fine before crash. No body damage or engine compartment encroachment; hit curb @15 - 20 mph. Greatly appreciate your time and consideration.
Sunday, October 25th, 2009 AT 3:18 PM
Hi jhaugh and TY for the donation
Check the fuel pressure if okay test the throttle position and mass airflow sensors
Sunday, October 25th, 2009 AT 5:26 PM
JHAUGH
The fuel pressure checks out. I removed the air duct from the throttle body and got a little bit more rpm, but when I put it in gear it still stalls out.
Saturday, October 31st, 2009 AT 12:51 PM
Okay clean out the idle air control valve and follow up with the other stuffs I've mentioned earlier
Saturday, October 31st, 2009 AT 5:18 PM
