1994 Ford Ranger Car Stalls While Driving
DIRT&MUD
  • 1994 FORD RANGER
Engine Mechanical problem
1994 Ford Ranger 4 cyl Two Wheel Drive Manual
Car stalls while driving. Will turn over but not start up. Had the fuel pump and fuel filter changed and the next day it stalled on the road and had to be pushed.
Please, any suggestions
Friday, September 5th, 2008 AT 9:57 AM
RENAUDTN
  • 636 POSTS
I would start by doing a fuel pressure test.
This will tell you if your fuel system is working alright.
If no pressure or low pressure, you'll need to check the fuel system (fuel lines, fuel pump wiring, relay, fuel pressure regulator, injectors, make sure the safety inertia switch is not tripped, etc
Another quick check would be to push the throttle open and spray some starting fluid in the engine while someone is trying to turn the car on. If the car starts for a few seconds and die, you have a fuel problem (fuel doesn't reach the engine). If it doesn't start you likely have an ignition problem.
Check that, and come back if your car still doesn't start.
You should also check for DTCs; maybe you'll find something there.
Friday, September 5th, 2008 AT 3:33 PM
