I found the black connector with the orange/black wire and the red wire. Upon unhooking the wire connector the red brake and amber ABS light on the dash began to cycle correctly even with engine running. However I was unable to get a blinking light code. I could not figure out how conduct the Test D.
At any rate I haven't gained any ground on the problem. On the way home under normal city driving I had to break somewhat hard once causing both the red and amber brake dash lights came back on and stayed on.
What next please.
Updated 3/23/2010
As soon as I disconnected the terminal pair the orange ABS and red Brake warning lights went out.
I went ahead and grounded the orange/black wire side for a couple seconds with no results (lit or blinking lights) anywhere.
With connector disconnected and lead not grounded I turned off ignition.
When I turned the ignition back on - the red brake light comes on momentarily while the orange ABS light stays lit until some servo motor completes its cycle.
So I go to Test D under PRE-CHECK TESTS but I cannot locate the PRE-CHECK TESTS nor Test D.
Back to you, thanks, Bill
Further information: I reconnected the orange/black to red wire connector.
Once again the ABS orange and the red brake lights remain on.
These lights working properly only concerns me if they are related to the engine stall problem. Thanks, again, Bill
Tuesday, March 23rd, 2010 AT 8:01 PM
