1993 Ford Ranger plugs are firing and fuel pumps working bu
JASON ELKINS
MEMBER
1993 FORD RANGER
4 CYL
2WD
MANUAL
250,000 MILES
Plugs are firing and fuel pump is kicking on but it wont start, even spraying gas or starting fluid in throttle body.
Sunday, June 13th, 2010 AT 9:33 AM
MECHANIC
If it doesn't start with starting fluid, then either you have a weak spark or the timing is an issue. Have you checked the timing belt? Compression? Injector pulse?
SPONSORED LINKS
Monday, June 14th, 2010 AT 1:09 AM
JASON ELKINS
MEMBER
No, I havn't, But I will. Thanks for the info. I thouhgt maybe it had jumped time, but I hav'nt had time, do to work, to have it checked. Thanks again.
Wednesday, June 16th, 2010 AT 6:43 PM
MECHANIC
I'm glad to help. Let me know what you find. Also, if the timing turns out to be good, you may want to check engine compression.
