Engine Stopped Suddenly No Spark?
PISTOLNOON
  • 6 POSTS
Electrical problem
1993 Ford Ranger 4 cyl Two Wheel Drive Manual
I was driving my 93 Ford ranger and it stopped suddenly down the road and I thought maybe it had run out of gas.So I put some gas in and started to crank the motor over but because it was the side of the highway I could not hear the fuel injection pump priming.So I had it towed home. At home I checked the fuel pump and it is priming.I checked the two relays under the hood and they are good, the diode their is also good.The engine cranks over and I checked the spark plugs for spark and their is no spark.So I suspect the coil, the ignition control module or possibly the crankshaft position sensor but the crankshaft position sensor cannot be found?I would like to diagnose the ignition system but I do not know what to look for as for values and positions and where the cranksft position sensor may be or how this ignition works enitrely, and so I need some assistance detecting problems with this ignition to see if this is the problem then procede with a good diagnostic.
Thankyou
May 30, 2009 at 6:32 AM
KHLOW2008
  • 41,812 POSTS
Thank you for the donation. You listed the engine as 4 cyl so I hope I got the correct engine info for you. It is a 2.3 L engine that I am refering to.
https://images.2carpros.com/forum/automotive_pictures/192750_EngComp93Ranger_1.jpg
Did you check if the camshaft is turning while cranking? It could be a bad timing belt. Crank Positioning Sensor is inside the timng belt cover.
May 30, 2009 at 5:42 PM
PISTOLNOON
  • 6 POSTS
Thankyou, It is to late to do it today so I will have time tomorrow afternoon, I will check the timing belt and crank sensor. How does the sensor work?Is it magnetic?Visual, some type of laser diode? So, I would know the DMM check to perform-continuity or resistance?
Also how would one check the coil, it seems like it is a DIS system one for the fuel injectors and one for the spark plugs.
Will get back to you tomorrow.I will also get more info on model.
May 30, 2009 at 6:23 PM
KHLOW2008
  • 41,812 POSTS
Crank Position Sensor. Used on 2.3L and 4.0L and mounted on front of engine behind vibration damper, sensor is a dual hall effect type with 50 percent duty cycle and an amplitude ranging between 0.4 and 13.0 volts. There are various systems so the correct data is important.
https://images.2carpros.com/forum/automotive_pictures/192750_IgnitionSystemApplication_1.jpg
May 31, 2009 at 12:50 AM
PISTOLNOON
  • 6 POSTS
Thanks will be in touch.
May 31, 2009 at 2:53 PM
PISTOLNOON
  • 6 POSTS
Ok got a better look at it and it appears that the timing belt has torn and is extremely worn out.Can a person take a standard timing light and check the timing?It looks like the power stearing, alternator, harmonic balancer, all have to come out?How far would the belt slip to make timing stop an engine?Or would it be catastrophic?Their are no signs of severe damage but I will check compression just to be safe.
So I ordered a timing belt, and when I get it off I will check the crankshaft position sensor to see if it is Ok or bad.
Would one set the piston for top dead centre, and check for another mark elsewhere?
Jun 2, 2009 at 7:07 PM
KHLOW2008
  • 41,812 POSTS
Hi again, You did not tell me the engine type and from the info, I guess it is a 2.3L as it has a timing belt. Some timing lights would not work on a DIS system. The belt did not slip. The most common fault would be missing tooth on thebelt and it usually happens at the crank sprocket. Anything more than 2 tooth out of position would cause non starting. Yes, you have to remove the external beltings and pulleys to replace the belting. Here are the removal and installation procedures. Since you have a broken belt, turn the crankshaft away from TDC before attempting to get the camshaft pulley marks into position.
https://images.2carpros.com/forum/automotive_pictures/192750_TimingBelt93FordRanger0a_1.jpg
https://images.2carpros.com/forum/automotive_pictures/192750_TimingBelt93FordRanger0b_1.jpg
https://images.2carpros.com/forum/automotive_pictures/192750_TimingBelt93FordRanger0c_1.jpg
https://images.2carpros.com/forum/automotive_pictures/192750_TimingBelt93FordRanger0d_1.jpg
https://images.2carpros.com/forum/automotive_pictures/192750_TimingBelt93FordRanger01_1.jpg
https://images.2carpros.com/forum/automotive_pictures/192750_TimingBelt93FordRanger02_1.jpg
https://images.2carpros.com/forum/automotive_pictures/192750_TimingBelt93FordRanger03_1.jpg
Jun 3, 2009 at 2:09 AM
WILLIAM PENDLEY
  • 15 POSTS
New coil packs two. new spark plugs eight. New spark plug wires eight. Still no spark on passenger side cylinder first plug closest to belts. Does camshaft sensor have anything to do with this problem? Every now.and then it would get spark and motor would run right but short lived. Please help if you may know what's going on because i am stumped. Thanks. Lee.
Jul 29, 2020 at 4:45 AM (Merged)
STEVE W.
  • 15,368 POSTS
Welcome to 2CarPros. The cam sensor would shut down all of the plugs not just one. Your description sounds more the the ignition control module having a bad transistor driver for cylinder one. It is the only part that controls which cylinders fire at what time. I would start by removing it, cleaning the areas around the screws (they ground the module) then apply some dielectric grease and re-mount it. See if the cleaning of the grounds and reseating the connectors cleared up the problem. If not you will want to replace the module.
This guide can help us
WILLIAM PENDLEY
  • 15 POSTS
Mr.Steve thank you so kindly. Will let you know.the results tomorrow!! Lee..
WILLIAM PENDLEY
  • 15 POSTS
Mr.Steve goodmorning. Here is a photo! What do you think?
WILLIAM PENDLEY
  • 15 POSTS
Mr. Steve my brother. I followed your steps and i want to thank you for taking time out of your life to help me. Just to let you know. My truck listed above is running better than it ever has. Thanks again. Lee!
STEVE W.
  • 15,368 POSTS
Great to hear. The pictures looked like it had a lot of corrosion. Please return anytime with your automotive questions.
TROYMCCONNELL7856
I am having trouble's with my 93 ford ranger with a 3.0 and I can't get no spark after changing distribtor's coil n computer and still have no spark at all can't figure out what it is
HMAC300
  • 48,601 POSTS
check fuses first and pcm relay then check red/lt grn wire on ignition moduel , dist and coil and see if power is going there. it may be a bad connector on either end and or a coil isn't good.
WILLIAM PENDLEY
  • 15 POSTS
Hi Mr.Steve. the truck is doing it again. This time the spark to that cylinder is staying longer then stops sparking. What do you think? Could it be the ICM going bad or something else?
WILLIAM PENDLEY
  • 15 POSTS
Mr.Steve, i didn't put any dielectric grease on it before i put it back on. would that be the cause and why?
WILLIAM PENDLEY
  • 15 POSTS
Mr.Steve my ICM has only 3 screws . There are 4 holes on the ICM but on the manifold there is only 3 screw holes.
STEVE W.
  • 15,368 POSTS
Sorry to hear that, more than likely it is failing because it didn't have a good ground for a while and it started damaging the transistors that are in the ICM. The cleaning showed it had an issue but it was a bit late to fully cure the problem. Replacing it should take care of the misfires and give you back a running truck. As for the 3 mounting screws, that isn't a problem, the two that ground it would be on the side where your screwdriver is pointing. The "missing" one isn't really needed. It's another of those "cost savings" items companies are famous for. The grease is there to allow for better heat transfer between the module and the manifold, leaving it off wouldn't be good for the long term but your module was already showing signs of failure so it wasn't the cause. When you install the replacement you can coat it with a thin layer. There will usually be some included with the new module. Check before you leave the store.
KVGOMEZ88
Hi I have a 93 ford ranger WITH a distributor cap its not the Vulcan motor im lost in what to replace next ive replaced the distributor cap the rotor the wires the plugs the ignition coil and im still not getting spark at the plugs im gonna replace the gear drive as ive heard that is a common problem in these trucks put I also read that the crank sensor or camshaft sensor can be the problem but when I look up where the camshaft sensor is on my truck I can't find any info to where its at or how to replace it please help me
WRENCHTECH
  • 20,760 POSTS
Why don't you stop simply throwing parts at it and start doing some testing. The first step is to test for injector pulse as a Crank Sensor issue will kill pulse also. If you have no pulse, test for power supply at the injector with the key on.
WILLIAM PENDLEY
  • 15 POSTS
Mr. Steve awesomeness thank you. I will change out ICM and let you know how it goes. Lee!
WILLIAM PENDLEY
  • 15 POSTS
Mr.Steve, would a bad relay in the fuse box under the hood cause this kind of issue? I don't know that's why i come to you.
STEVE W.
  • 15,368 POSTS
Nope, The ICM controls it all when it comes to the spark plugs. It determines which plug and when to fire. A bad relay would knock out the entire module so you have no spark at all. Same if it was a bad crankshaft or camshaft sensor, they would shut off all spark.
The wiring diagram is the modules connections. Notice the pins saying coils 1-4? Those are what tells which coil to fire. Check them over to be sure there is no corrosion or bad connection for the one labeled coil 1 (pin 11) That would be the only spot other than a bad coil, plug wires or plugs that would stop spark on cylinder 1.
Here is the theory of operation for your DIS system.
The Distributorless Ignition System (DIS) module performs the following important functions:
- provides a ground for the ignition system through two of the module mounting screws
- selects which ignition coil within the coil pack to fire
- contains solid-state electronic switches that control current to the coil primary circuits within each coil pack
- limit current flow in each coil primary circuit to a maximum of 5.5 amps
- generate the Ignition Diagnostic Monitor (IDM) signal; this provides diagnostic information about the ignition system to the Powertrain Control Module (PCM).
- provide Failure Mode Effects Management (FMEM) operation.
The second item in that list is the important one in your case. The module selects which coil to fire and when based on the signals it gets.
CONSTRUCTION
The DIS ignition module is a thick film integrated design. The module contains a ceramic substrate thick film assembly and four output drivers mounted on a metal base plate and potted in a plastic housing.
OPERATION
The DIS ignition module receives the PIP (Profile Ignition Pickup) and CID (Cylinder Identification Device) signals from the crankshaft sensor and Spark Output (SPOUT) signal from the PCM. During normal operation, PIP is sent to the PCM from the crankshaft timing sensor and provides base timing and RPM information. The CID signal provides the DIS ignition module with the information required to synchronize the ignition coils so that they are fired in proper sequence. The SPOUT signal contains optimum spark timing and dwell time information. Spark angle is determined by the rising edge of SPOUT, while the falling edge of SPOUT controls the coil current "ON" or "DWELL" time. The dwell time is controlled or varied by varying the duty cycle of the SPOUT signal.
WILLIAM PENDLEY
  • 15 POSTS
Mr Steve. sorry it took so long to get back with you. I put another ICM in and seems to be working okay. Also put new relays in. Now i have a hard time starting it. It cranks awesome just so very hard to get it started. First ignition key turn motor jumps like it going to start then doesn't. I have to turn key off wait a few sec then turn the key again. I do this about 15 to 20 times be for it starts.when it does start the fumes from exhaust burns my eyes. Any ideas ?
WILLIAM PENDLEY
  • 15 POSTS
Mr. Steve would the inertia switch have anything to do with the starting issues?
EDWARD J JASINSKI
have charged battry, new module, starter tests fine, and new ignition switch
  • 75,988 POSTS
1993 Ford Ranger no spark
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor /distributor pick-up coil, ignition control module, ECM,Ignitor cam and crank sensors- Note: If it doesn't apply disregard it
STEVE W.
  • 15,368 POSTS
The inertia switch would shut the fuel pump off and the engine wouldn't run at all so I doubt it is the issue. I would recheck the firing order and wires. it sounds like there is an issue with the timing or firing order. That would push fuel fumes out as well and in a cold engine they would cause some nasty fumes.
WILLIAM PENDLEY
  • 15 POSTS
Yes sir, will get out there tomorrow an try what you said. Thank you and will get back to you on what i find out!!
WILLIAM PENDLEY
  • 15 POSTS
Mr. Steve. is the firing order side the drivers side plugs and coils.
WILLIAM PENDLEY
  • 15 POSTS
I went a head and did all of them this morning. It was 38 here cold. I turned the key and it started right up and no fumes. Purrs like a kitten. You are awesomeness.thank you so much.if ever i have any problems again you are the one i want to talk to. You truly know your stuff. Thanks again my brother. Lee !
LSTADE
Engine Mechanical problem
1993 Ford Ranger Four Wheel Drive Manual
Pickup has a 3.0 engine. It died on me, restarted after 10 minutes, ran fine rest of day, then next morning wouldn't start. There is no spark. Have checked CAM sensor, distributor, fuses. All are ok. Where is the ICM and any ideas on what else we can check?
  • 75,988 POSTS
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it. See below:
https://images.2carpros.com/forum/automotive_pictures/12900_i_5.jpg
In left front of engine bay,on upper radiator support.
STEVE W.
  • 15,368 POSTS
Great to hear you figured it out. 38 is almost cold... LOL If you have any other automotive questions we will be here. Thank you for using 2CarPros.
WILLIAM PENDLEY
  • 15 POSTS
Mr. Steve, it is me again lol. Went to start her up and it was hard to start. I noticed the fuel pump turn on when i turn her over and wouldn't turn off. After 5 or 6 tries turning her over the first time the fuel pump turned on then clicked off she cranked right up and ran great!! Why would a fuel pump stay on when key is turn to on position? Any idea ?
STEVE W.
  • 15,368 POSTS
Could be a relay that is starting to fail. The way the circuit works is simple, When you turn the key on, the PCM then turns on the pump relay for about 2 seconds, this is to bring the fuel pressure up in the event that any has leaked down while it sat. Then the relay turns off. When you turn the key to start it turns it on again and once the PCM sees an RPM signal of more that 120 rpm it turns the relay on full time and the engine runs. If the PCM sees that RPM signal drop below 120 or stop it shuts the pump relay off. If the relay contacts get bad they can stick. Another reason they can fail is if the fuel pump itself is starting to go bad and it's drawing excessive current. When that happens the contacts can spot-weld themselves together. That isn't hard to test but it takes an ammeter that can read up to 20 amps. Then you put it between the power feed and the pumps power lead. If you see around 5-8 amps it should be fine. Higher than that could be a bad pump. Personally I'd just replace the relay and see how it acts. If it has never been changed it's probably just worn out.
WIGGEY
Suddenly my tired old Ranger doesn't start. I have no spark at all, so I have taken the ign. module & the primary coil to O'rielly's & they both checked ok. Best I can figure it must be the crank position sensor, or the ECM itself. Thinking the ECM is seldom the problem, that leaves the CPS. Due to the high cost of this part I need to be positive the current one is bad before buying a new one, I need to figure out a way to test the old one. Any idea's? Also, the main connector from the CPS is a 4 wire plug. The CPS also has a single wire with connector coming out of the same wiring bundle. What is this single wire for? The power to the CPS? The signal from the CPS to the Ign. control module? If possible I want to test the CPS w/o removing it.
I thank you in advance for any help you can give. wiggey
Jul 29, 2020 at 4:46 AM (Merged)
BMRFIXIT
  • 19,053 POSTS
when you turn key on do you have check engine light on
if no light check fuses and relays
you can use an ohm meter to test CPS
WIGGEY
As to the check engine light, it is on only as it does when first starting to verify it works. Besides, I removed the battery so wouldn't that have erased any codes it had set? It was not on previously that I remember. Perhaps if I just crank it with the starter for 15-20 seconds might that set a code?
I will check all fuses again, but I do not know how to check a relay other than to remove the relay in question and swap it with another identical relay.
The test procedure I found for the CPS says this:
Measure voltage between the CID terminal & grnd by backprobing the connector. Sensoi is ok if voltage varies more than 0.1 volt with engine running at various RPM. Hell, If the engine WAS running, I wouldn't even BE testing the CPS, would I?
Can I unplug the connector from the CPS & take a reading from the CID terminal & ground by just turning engine over with the starter?
Again I thank you in advance for your assistance.
wiggey
BMRFIXIT
  • 19,053 POSTS
With key on and check engine light comes on , that will suggest that the computer is powered and its fuse and relay in working condition
as for a crank sensor you can disconnect it and check is using an ohm meter or volts meter (ac volts should generate as you crank if sensor any good )
also I would check for battery power at the coil terminals
check TIMING BELT
