1992 Ford Ranger clutch
SHOOTER41
  • 1992 FORD RANGER
  • 4 CYL
  • MANUAL
  • 153,000 MILES
Just put in transmission and now the clutch won't push down, can you help please?
Saturday, April 12th, 2008 AT 7:24 PM
  • 31,937 POSTS
Hi there,
may need a bit more information but will see how we go. If the pedal it up and locked (wont depress) crack the bleeder and see if the pedal goes to the floor, if so the Hydraulics ar ok and there is a mechanical problem with the clutch, if the pedal wont depress, start checking around the master Cly for a fault. Start here.
Mark (mhpautos)
Saturday, April 12th, 2008 AT 8:44 PM
SHOOTER41
Where do I bleed it
Sunday, April 13th, 2008 AT 6:53 AM
  • 31,937 POSTS
There will be a bleeder at the slave cyl at the gear box, it will look the same as a bleeder on a brake caliper.
Mark (mhpautos)
Sunday, April 13th, 2008 AT 5:35 PM
