1988 Ranger oil pressure light
JONAHBEAST
  • 1988 FORD RANGER
I have a 1988 Ranger with about 130,000 miles. I've only owned it for about a year, so don't know much about the repair history. I do know that the fellow who owned it before me was very careful about keeping up with maintenance, oil changes, etc.
My problem is that when I start the truck the oil pressure light stays on for a long time. I don't know if I'm going to damage the engine because of this. Once the truck is warmed up the light goes off and the problem doesn't re-occur unless the truck sits for many hours (ie: overnight). The problem is getting worse as the temperature gets colder. In summer it went off in about 15 seconds. Now it's going on and off for about 5 minutes.
The truck runs well. There are no funny sounds, smells, etc. It does use a bit of oil. I have to add a quart after about every third gas tank fill-up.
Any suggestions? And most importantly, am I likely to be doing engine damage? I don't really have the money for a repair right now. Hoping this might be able to wait a few weeks as long as I warm the truck up well before driving. Thanks!
Saturday, November 3rd, 2007 AT 9:36 AM
CHEVY22
  • 1,375 POSTS
Hi
sounds like this may just be a bad oil switch that gets worse when the oil gets thicker (colder outside), with no noise or indication of oil pressure low at this point. The switch is cheap, I would replace it and let us know what happens
jim
Saturday, November 3rd, 2007 AT 5:57 PM
JONAHBEAST
Thanks for the suggestion! I appreciate it.
Saturday, November 3rd, 2007 AT 6:47 PM
CHEVY22
  • 1,375 POSTS
No problem, good luck
jim
Saturday, November 3rd, 2007 AT 6:51 PM
