Oil light
200,000 MILES
WRENCHNIT12
My oil light comes on sometimes at idle but then goes away with rpms. I checked the oil level and it is fine. Oil pump? Ghjkkohgtrrrdfvvddssdfhjkiikjhggf blah blah blah blah yadda yadda yadda r u kidding me about to give up on this b*******(200 characters????????????????????????)
May 5, 2013 at 2:53 AM
HMAC300
  • 48,601 POSTS
try changing the oil and use a quality oil filter like wix, napa, or Purolator. That may cure it if not have it manually pressure checked. if still low it may be main bearings or rod bearings or both.
May 5, 2013 at 2:56 AM
