1988 Ford Ranger Exhaust and Catalytic Converter
148,000 MILES • 6 CYL • 4WD • AUTOMATIC
B2SKOW
My 1988 Ford Bronco 2 has a 2.9L V6. I busted a hole in the muffler almost 2 years ago and ripped it off cuz it was just rattling around. I have gone without a muffler for over a year now. My Cat. is now getting a TON of back pressure and blocking up and I can only go a sad little 35mph. I am going to remove it and run strait piping to Flowmaster, and then dump the exhaust right after the muffler. The muffler itself will end about 16" in front of the passenger rear wheel on the inside of the frame. Will it run okay? Will it burn up like my Cat. ? Will it sound okay? I am not sure.
Oct 5, 2009 at 3:23 PM
  • 110,248 POSTS
We recommend replacing with direct fit parts. First, it is against the law to remove the converter, and second, the exhaust must exit the vehicle from beyond the passanger compartment. Thus, you shouldn't end it under the vehicle.
As far as the converter, you are going to cause other engine related problems by removing it. The O2 sensor will not send a signal to the computer. Therefore, the air / fuel mixture will be wrong.
Seriously, if you want the flowmaster sound, do it. But, you should have a converter and the exhaust should exit beyond the passanger compartment.
Oct 28, 2009 at 1:23 AM
