I need a fuel pump wiring diagram
JOHNWMOORE92
  • 1994 FORD RANGER
  • 180,000 MILES
The wires on fuel pump harness are all wrong. I need a fuel pump wiring harness to match the correct wires. Thank you.
Wednesday, August 31st, 2011 AT 9:20 PM
Check out the images (Below). Please let us know if you need anything else to get the problem fixed.
Monday, September 16th, 2019 AT 10:47 AM
JOHNWMOORE92
Thank you, this is what I needed.
You're welcome
KJT2548
  • 1994 FORD RANGER
  • 6 CYL
  • 218,000 MILES
Fuel pump replaced no power to it
Thursday, July 1st, 2021 AT 1:12 PM (Merged)
KHLOW2008
  • 41,814 POSTS
Hope the diagram is helpful. Red wire is power supply from PCM power relay. Light Blue/Orange is to Data Link Connector.
Thursday, July 1st, 2021 AT 1:13 PM (Merged)
WRENCHTECH
  • 20,761 POSTS
Just a small addition to KHLow2008, make sure you are testing it properly. It only powers for 2 seconds when the key is first turned on and not again until it sees a tach signal from cranking.
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Here is an addition to the wiring diagram information you requested. First, here is a wiring testing tutorial for you to view:
I've attached a factory Ford diagram and and aftermarket color wiring diagram for your truck. I've cut the diagram into 3 pieces so you can view larger. These diagrams cover the fuel pump circuit you were looking for. Hope this helps and thanks again for using 2CarPros.
CHUBSHOUSE
  • 1993 FORD RANGER
  • 4 CYL
  • MANUAL
  • 170,000 MILES
We have a 93 ford raner 2.3L 5 speed. There is no electric to the fuel pump. We have checked the inertia switch changed fuel pump relay, fuel pump and filter and we still have no power. What could it be. It cranks and fires but doesnt start.
JDL
  • 16,098 POSTS
Check fuse 18--20 amp in the underhood fuse box. Use a voltage tester, is the fuse circuit hot? If not there is fusible links up by the starter solenoid pull on them to see if one is rubbery.
CHUBSHOUSE
Yep the problem was the fusible link once I replaced it the system came back to life I love this site!
FWORKMAN
  • 1993 FORD RANGER
Six cylinder two wheel drive manual.
I just recently received the truck listed above it has a 3.0 liter engine. Someone has done not so good work on the vehicle, and I want to get back up to spec. Anyway, I had to replace the fuel pump connector, however the new connector is not color coded with the original harness. It is a 4 pin connector, and I know what each wire is associated with, but, do not know the position. I have asked some friends at the dealership, but, regretfully their manuals do not have the connector diagram, and, the schematic is not helpful. Could you please give me the color code wire position for this connector?
INTERNETMECHANIC
  • 700 POSTS
I found this information (below). As far as the connector, I do not think you can wire it wrong. Whatever color wire is on the outside left of the old connector, place it in the same position on the new connector and so on.
https://www.2carpros.com/forum/automotive_pictures/512072_ranger_fuel_pump_2.jpg
FWORKMAN
Thanks for the reply, but, I have the schematic. The problem lies in the fact that the old connector was gone, and I have no idea what wire went in what position. That is why I am asking for the color code and position they went to.
INTERNETMECHANIC
  • 700 POSTS
The wiring diagram gives you the wire color. And the voltage. Pink wire with black tracer is voltage for pump motor. Black wire is ground for pump motor. Yellow wire with white tracer is voltage for sending unit, fuel gauge. Black wire with yellow tracer is ground for sending unit. I will see if I can find a color coded pump connector? I found these wiring colors, below.
https://www.2carpros.com/forum/automotive_pictures/512072_ranger_fuel_pump_wiring_1.jpg
CASEYJBROWN
  • 1988 FORD RANGER
  • 200,000 MILES
I have ranger 4X4 2.9L V6 engine. I am having problems tracing down the wires that connect the fuel pump to the other components before it. The relay's are working, the inertia switch is working and the pump itself works. Fuel pump in tank is barely a year old, external pump works but was on the vehicle when we bought it.
FWORKMAN
Now that information rocks! Is that a picture of the pump for a Ford Ranger? If so, then I could trace the wires from the pump to the connector, yes?
Regardless, you have been more help than any other forums that I have been looking at. Just for information like that you could be a millionaire, and save a lot of people's blood pressure from going up. Thank You very much! :)
HMAC300
  • 48,601 POSTS
Here is a diagram. Bu t it there is one on the frame then the one in the tank went bad maybe or the inertia switch or relay quit. But probabl the tank. It's easier if you have a few friends around to lift the box off teh truck andreplace fp that way.
INTERNETMECHANIC
  • 700 POSTS
That picture came out of a parts book for 1993 Ford Ranger, 3.0 liter engine. I cannot guarantee the picture is correct, that was all I could find.
TLEER2009
  • 5 POSTS
  • 1986 FORD RANGER
I need the Fuel pump Wiring diagram for a 1986 Ford Ranger with a 2.3 engine?
https://www.2carpros.com/forum/automotive_pictures/12900_fuel_pump_2_1.jpg
