INSTRUMENT CLUSTER Removal Disconnect battery negative cable. Remove 2 screws attaching steering column shroud to panel. Remove shroud. Remove lower instrument panel trim. Detach cluster trim cover attaching screws and remove cover. Remove 4 screws attaching cluster to panel. Pull cluster slightly away from panel. 2) Disconnect speedometer cable at speedometer. If there is not enough room, detach cable at transmission. Disconnect wiring harness connector from printed circuit. Disconnect any light bulbs from sockets and remove instrument cluster. Page 1 of 1 3/13/2010
http://www.ondemand5.com/mric/common/asp/Article.aspx?MOD=REPART&YEAR=19 ...
Check the gear at the tranny end before you start...not real hard to di this!
Mar 13, 2010 at 3:05 AM
