1994 Ford Probe Gas from Throttle Body
METAL_DISASTERPIECE
  • 5 POSTS
94 Ford Probe GT, 2.5LV6 24 valve DOHC, 5 speed tranny 124,000 miles,
The car is shooting gas out of the throttle body, right where the air intake hose connects, What the heck is causing this? PLEASE HELP!!
May 20, 2007 at 10:12 AM
RUDPRO
  • 224 POSTS
I'd check the fuel pressure regulator. It has a vacuum hose going to it. When the diaphram in the regulator goes bad, fuel can get into the vacuum lines.
May 20, 2007 at 6:44 PM
Suggested Repair
Check the fuel pressure regulator and its vacuum hose. A failed regulator diaphragm can let fuel enter the vacuum lines and spray out at the throttle body where the intake hose connects.
Conversation Summary
The owner of a 1994 Ford Probe GT reports fuel spraying from the throttle body at the air intake hose connection. The expert recommends checking the fuel pressure regulator, explaining that a bad diaphragm can send fuel into the vacuum lines.
