1995 Ford Probe Wrong Oil Filter Damage
ASSANOWICZY
Took 1995 2.5 24v Probe to local garage to fit new oil filter and oil change. THEY FITTED THE WRONG FILTER : (
Engine overheated, water and oil dried up.....engine now smoking - loads of back pressure in main raidiator hose - guess they have blown my engine.
Can I take it to Ford and insist that the garage pay the bill - I don't want to let those cowboys anywhere near it - if they can't get an oil filter right - they aure as hell aint gonne fix my head gasket/head or whatever else they have wrecked. :shock:
Apr 2, 2006 at 5:23 AM
LOSONE
  • 1,616 POSTS
I don't know where you live but in this case see an attorney after you have a mechanic verify what was done wrong. Good Luck
Apr 2, 2006 at 6:52 AM
OILPAN49
  • 18 POSTS
Ditto.
My apologies man! I hope you get things straightened out and that garage sounds like they own you a new engine.
If the filter was wrong, the threads shouldn't of accepted the filter. My guess is the filter went on awkward, they didn't care and just slap it on there.
I'm with losone, get a lawyer A.S.A.P and I hope all goes well getting this thing straightned out and see too it that the garage gets you a new engine and have someone else install it. Good luck man! -op-
Apr 2, 2006 at 6:05 PM
Suggested Repair
Have an independent mechanic verify the wrong oil filter and resulting engine damage, then consult an attorney about holding the original shop responsible. Do not return the car to that shop for repairs.
Conversation Summary
The owner of a 1995 Ford Probe says a garage installed the wrong oil filter during an oil change. The engine then overheated, lost oil and coolant, began smoking, and developed back pressure in the radiator hose. Replies advise documenting the error with another mechanic and contacting an attorney rather than letting the original garage repair it.
