Ford Probe GT EGR 1997
BUFORDEMU
I had the check engine light come on, and it was code P0400, EGR problem. I had another used EGR valve, replaced it but the light came back on. I replaced the EGR boost sensor (new), didn't fix it. I then replced the MAP sensor, again, no luck. I could not find any other components pertaining to the EGR system, so I replaced the EGR valve with a new one. Light came back on. I did run a wire through the egr exhaust port in the head, and didn't find any blockage (however I could only go so far and I'm not sure I got all the way through).
Is there any other component or test I should make that I'm missing?
Ken
Nov 2, 2007 at 11:46 AM
  • 75,988 POSTS
Is it a 2.0 or 2.5L engine?
Nov 2, 2007 at 6:32 PM
MERLIN2021
  • 17,250 POSTS
Yes you need to clean the carbon out with , I use a length of coathanger, all the way to the throttle plate. then reset the light, if it comes back, replace the EGR Position sensor...
Nov 2, 2007 at 11:34 PM
BUFORDEMU
[quote:4393be7f90="rasmataz"]Is it a 2.0 or 2.5L engine?[/quote:4393be7f90] It's a 2.5 V6
Nov 3, 2007 at 1:34 AM
BUFORDEMU
EGR passage was clogged/gummed up at the exit point in the manifold, which is at the throttle body extrance. Cleaned it out and no light so far. It did display a P0505, "Idle malfunction" at first, but has idled correctly since then, and no other lights.
Nov 11, 2007 at 12:16 AM
