1989 Ford Probe OBD-1 Codes
JONS89PGT
  • 8 POSTS
My 1989 Probe is supposedly OBD-1 compliant... you ground the STI connector then count flashes on your steering wheel console (CHK ENG lite)....
my question, is there another way to get the codes? can you use a OBD-II machine for OBD-I cars? thanks
Mar 16, 2007 at 3:06 PM
KIN CHAN
  • 453 POSTS
do you mean a OBD2 scanner/code reader? if a code reader or scanner is design to communicate with OBD2 then the connector will not plug to an OBD1 car. just that simple, but if the scanner or coder reader is capable of both. You want to make sure it has the Ford OBD1 connector. all OBD1 connectors to all makes are different while OBD2 connectors is standard one size fit all. which is mandated by the government...
Mar 16, 2007 at 6:52 PM
TAURUSWHEEL
  • 718 POSTS
Go to your auto parts store, tell them you want an obdI code scanner for Ford, probably cost you $30.00 or so, not only will it read codes, it can do a few other simple tests for you. simple to use..
Mar 17, 2007 at 10:28 AM
Suggested Repair
Use a Ford-specific OBD-I code scanner rather than a standard OBD-II reader. An auto parts store can supply a Ford OBD-I scanner, typically around $30, that reads codes and performs a few simple tests.
Conversation Summary
The owner of a 1989 Ford Probe asked whether an OBD-II scanner can read OBD-I codes instead of grounding the STI connector and counting check-engine light flashes. Replies explained that a standard OBD-II connector will not fit an OBD-I car unless the tool also has the Ford OBD-I connector, and recommended buying a Ford OBD-I scanner from an auto parts store.
