A/C Squeals when engaged at at low RPM
FORD PROBE
BANZAIL
1997 Probe GT with 114,000 miles...I get a terrible squeal from under the hood if I engage the air conditioner at low rpms...if engaged at speeds above 20 mph I get no squeal...belt is tight and in good condition and air conditioner cools very well...a friend mentioned something about too high of pressure locking up the compressor?...what can I do?
Thanks!
Aug 11, 2007 at 9:44 AM
[quote:6b3006f163="banzail"]1997 Probe GT with 114,000 miles...I get a terrible squeal from under the hood if I engage the air conditioner at low rpms...if engaged at speeds above 20 mph I get no squeal...belt is tight and in good condition and air conditioner cools very well...a friend mentioned something about too high of pressure locking up the compressor?...what can I do?
Thanks![/quote:6b3006f163]
If its a belt problem a 1/4 -3/8 belt deflection on the center of the belt should do it-if it continues the problem is coming from somewhere else. To ID disconnect it one at time to finger the location.
Aug 15, 2007 at 4:05 AM
