1989 Ford Probe 1989 Probe cold compression check readings
1989 FORD PROBE
103,418 MILES • 4 CYL • FWD • AUTOMATIC
MB700000
  • 6 POSTS
I bought an 89 Probe for a parts car. The previous owner new that the engine "just stopped running" and didn't want to mess with it. It gets a little fire to the plugs, but it has no gas tank to make things easy for me. I checked the compression (obviusly on a cold engine) and got these readings:
cylinder 1 45psi
cylinder 2 30 psi
cylinder 3 30 psi
cylinder 4 50 psi
The two 30 readings are on the center plugs.
Is there a chance that this engine might be good? This parts car looks better than the one that I CAN fix.
Thanks for your help! Mike
Jul 12, 2009 at 5:23 AM
BUDDYCRAIGG
  • 2,262 POSTS
there's something very wrong with the engine.
with "it just stopped running" I'm guessing the timing belt broke.
Jul 12, 2009 at 8:07 AM
MB700000
  • 6 POSTS
The timing belt is still intact. Thanks
Jul 12, 2009 at 8:13 AM
BUDDYCRAIGG
  • 2,262 POSTS
are any of the teeth missing from the belt?
It may have simply jumped time.
Jul 12, 2009 at 8:17 AM
MB700000
  • 6 POSTS
Timing belt teeth are all good. Cam timing lines up.
I used Sea Foam in the cylinders and have managed to get the compression up to these levels:
1 90psi
2 53psi
3 60psi
4 68psi
Fire is going to all the plugs. I'm assuming there's nothing more that I can do, so my sharper looking car will have to be my parts car. Is this your opinion, too? Or am I missing something?
Jul 14, 2009 at 12:27 PM
BUDDYCRAIGG
  • 2,262 POSTS
the lowest compression reading i've ever done on a running engine was +/- 95 across the cylinders.
you know you could have a blown head gasket. And the compression is leaking over into the other cylinder when you are doing your test.
Jul 14, 2009 at 3:53 PM
