1993 Ford Probe recharge a.c.
KDADDY
Air Conditioning problem
1993 Ford Probe 4 cyl Front Wheel Drive 100000 miles
where is the port to charge my a.c. thr is a valve on a canister but my recharge kit does not fit. just need to know wher to hook my recharge kit at.... its a ez chill r134a refridge plus oil. 18 oz.
Jun 28, 2010 at 2:09 PM
2CARPRO JACK
  • 11,533 POSTS
On a 93 you will have to get a conversion kit (or better yet, have it done).The r12 fittings are different and they need to be changed, and the oil needs to be changed to a 134a compatible type.Then the system needs to be vacuumed down to remove any moisture that is in there for it to work properly
Jun 29, 2010 at 12:54 AM
