I couldn't get the old unit to slide out - even pulling it with vise grips, but did get the cables unplugged and plugged into the new unit, which I just set next to the old unit.
Then I hooked the battery back up and tried to start the car. It's now saying that my fuel cutoff is tripped, only when I went to the button in the trunk it was still depressed. I tried pushing anyway, just in case I couldnt see it that well. And it still won't start.
When i turn the key, i here the little whirr of the fuel pump, but it doesn't even try to start. I've tried pushing the fuel cutoff a few more times, but still nothing different.
It ran fine before I changed the DM unit - could I have damaged something else by just replacing it?
Thanks!!
Aug 28, 2007 at 8:26 AM
