the other day my probe started to run hot so i imediatly pulled over and had it towed home. i found that the thermostat was stuck shut. it was easyer to take the radiator out while replaceing the thermostat cause i didnt know if it was that or the water pump. i started the car without the radiator and antifreeze went every where. when i replaced everything now i have now spark i replaced the spark plugs wires and distributor cap and still have nothing but the car was running the same day i replaced the thermostat
Mar 25, 2010 at 12:03 PM
