1990 Ford Probe Electrical Problems
JOE055266
Electrical problem
1990 Ford Probe 6 cyl Front Wheel Drive Automatic 129K miles
All at once the following stopped working.
Horn does not work.
Radio does not work.
Coolant Fan does not work.
Power Seat Belts do not work.
Interior dome light does not work
Tail lights do not work.
Brake Lights do not work.
Parking lights do not work
Automatic Stick shift does not move.
Dash gauge lights do not work.
What does work;
Headlights
Wipers
AC/Heat Fan
Car starts
Please Help!
I have check all fuses and they are in good working order.
What is happening?
Ugggggh
Dec 21, 2007 at 11:19 AM
2CARPRO JACK
  • 11,533 POSTS
Have you used a test light to verify power ot the interior fuse panel? These circuits dont share very much other than getting their power from the same place
Dec 22, 2007 at 3:25 AM
JOE055266
Thanks for your reply. I looked under the hood today and noticed a plastic wire plug connector that leads to a black box on the fireall melted. The plug connected 4 wires that lead from that black box towards the front of the engine. The wire colors were black, two aqua wires, one with a yellow strip and the other aqua wire with a black strip, and a creamish color wire. I cut the plug off and reconnected the wires but did not get any resolution. Could this be the black box? Many other wires lead to the black box.
Dec 22, 2007 at 3:45 AM
2CARPRO JACK
  • 11,533 POSTS
If those wires did carry power and melted, you might have a fusible link or other main fuse out. Did you verify power to all fuses with a test light? So many things not working, there will be a lack of power somewhere in the fuse/relay center
Dec 23, 2007 at 12:24 AM
