1989 Ford Probe Stalls in Drive
SAYS HE
PLEASE HELP ME. I HAVE A 1989 FORD PROBE AUTOMATIC WITH 165,000 KLM'S. THE THING IS, WHEN I START IT UP, IT RUNS GREAT. BUT WHEN I PUT IT INTO DRIVE, IT STALLS. I HAVE TO GIVE IT MAJOR GAS AND SLAM IT INTO DRIVE TO GO ANYWHERE. ONCE I'M OFF IT GOES GOOD BUT WHEN I GET TO A STOP LIGHT, IT WANTS TO STALL AGAIN. I PUT IT INTO NUETRAL AND SLAM IT INTO DRIVE AGAIN WITH THE REVS UP. IS THERE A RESET IN THE TRANSMISSION. MAYBE A HEAT SENSOR ACTING UP? IT DOESN'T DO IT IN REVERSE. DOES THIS TRANS HAVE A CILINOID. YOUR HELP WOULD BE GREAT
Jun 16, 2006 at 6:11 PM
TAURUSWHEEL
  • 718 POSTS
edited out, sorry
Jun 17, 2006 at 1:03 AM
TAURUSWHEEL
  • 718 POSTS
Any check engine light??? Sounds like the torque convertor is permantly locked up, will cause the car to stall.. if no check engine light,, have someone scan your car for codes, trans codes won't always set the light,, I recommend you buy yourself the code reader, about 39 bucks, Actron or others make them,, simple to use, invaluble tool, too much guessing without it.. there is a solenoid that controls torque comvertor lockup, could be bad....
Suggested Repair
Scan for transmission codes even if the check engine light is off. A permanently locked torque converter, or a faulty torque converter lockup solenoid, can stall the engine in Drive.
Conversation Summary
A 1989 Ford Probe automatic starts and runs well but stalls when shifted into Drive, especially from a stop, and does not do this in Reverse. The owner asked about a transmission reset, heat sensor, or solenoid. The expert said a locked torque converter can cause this stall and recommended scanning for transmission codes, noting the lockup solenoid may be bad.
