2000 Ford Windows Won't Roll Down
FORD
GOTTALOVEFORD
:cry: My windows do not roll down on my 2000 Ford half ton. I have talked to my local ford dealer, they told me that if the relay switch clicked when I turned the key on, then the relay was bad. It clicked. I replaced the relay, but that did not solve my problem. I have also checked my fuses and they are not bad. I recently had a new transmission put in the truck, could that have done something to my windows?
Thanks for all your help
Stephanie
Sep 5, 2006 at 4:17 AM
NOS
  • 320 POSTS
i have seen some really strage things happen in fords on an escort i seen a neutrial safety switch make a radiow quit when you pulled it out of park into gear so i would not put anything past ford lol :oops: it really sounds to me like they left a ground loose somewhere when they changed the trans out. if it was working trouble free before then i would suppect that. (NOS) 8)
Sep 6, 2006 at 12:43 PM
Suggested Repair
If the windows worked before the transmission replacement, inspect for a ground left loose or disconnected during that job. The relay and fuses have already been checked.
Conversation Summary
The owner of a 2000 Ford half-ton says the power windows will not roll down. The relay clicked and was replaced, and the fuses are good. The expert suspects a ground was left loose when the transmission was replaced, since the problem followed that work.
