Driver side power window won't go down
FORD
MAURY6024
Good morning, when I oush on the window down button the headlights dim and the window will not go down. If the window does go down about an inch it will stop. Using the up button the window goes up just fine. All other windows work fine. Is this most likely a window motor or something else?
Thanks for the help,
Maury
Dec 9, 2006 at 2:53 AM
BOOTDOG
  • 665 POSTS
i would look into checking the window regulator. if it goes down only about an inch then something is binding like a bent widow regulator, or even the window might be slightly off track. check that first. if thats fine then look into the window motor. :)
Dec 9, 2006 at 3:21 AM
HEY_WIRE
  • 25 POSTS
my grandma had the same problem i dont know if it is the exact same but her back window the button got stuck in the upward possition when she went to roll it down it wouldnt or if it did it would only go down about an inch and then stick if she hit the up botton it would go up by itself i took a look at it just took a little wd-40 and a couple of wiggles
the end
hope this helps
Dec 9, 2006 at 4:47 PM
