1989 Ford 300 No Spark
FORD
JFRANK
I have a 1989 ford 300 in a half ton pickup and I have no spark what is the most likely problem?
Mar 7, 2006 at 2:52 AM
EPYON2K1
  • 15 POSTS
Hey check the timming, if not, for good connection with the spark plugs, coil, Replace the ignition relay..... Hope this helps....
Mar 7, 2006 at 4:28 AM
PEPPERMRJ
  • 1,158 POSTS
TFI module, EEC IV module, and the coil, in that order. Here is a link on how ot test each.
Also some auto parts stores will be able to test the components if you take them in.
Good luck and let us know. :)
Mar 14, 2006 at 9:17 AM
Suggested Repair
Check the TFI module first, then the EEC-IV module, then the ignition coil. Some auto parts stores can test these components if you bring them in.
Conversation Summary
The owner of a 1989 Ford 300 in a half-ton pickup reports no spark and asks for the most likely cause. One reply suggested checking timing, spark plug and coil connections, and replacing the ignition relay. The expert recommended checking the TFI module, EEC-IV module, and coil in that order, and noted that some auto parts stores can test the components.
