1995 Ford Fiesta Heater Blows Cold
FORD
TUCKER05
my car is a ford fiesta 1.3 1995 89733. the heating in my car is not working and ive just changed the thermostat, its made no difference it is still blowing out cold air can anyone help?
Nov 22, 2006 at 5:52 AM
BRUCE HUNT
  • 3,754 POSTS
OK, check the hoses after the car has been warmed up well and feel them to see if they are hot. Then feel the heater hoses. One of them should be hot and since the system is not working the other should be cool. If so, follow the hot hose to a valve and see if the cable, wire, or whatever that controls it is working or not.
Nov 22, 2006 at 12:04 PM
Suggested Repair
With the engine fully warm, feel the heater hoses. One should be hot and the other cool if cabin heat is not working. Follow the hot hose to the heater control valve and check that its cable or linkage operates.
Conversation Summary
The owner of a 1995 Ford Fiesta 1.3 says the heater still blows cold air after a thermostat replacement. The expert advises checking hose temperatures once warm and inspecting the heater control valve and its cable or linkage.
