2003 Ford Police Interceptor Headlights Off
2003 FORD
INTERCEPTORMAN
I have an 03 Police Interceptor. I had a new alternator installed a month ago. About two weeks when I'm driving I'll hear a vlick in the dash and my headlight will shut off. The parking lights will stay on. After about en minutes I'll hear another click in the dash and the lights will turn back on. This will happen everytime my headlights are turned on. I went to the dealership and they installed a new headlight switch, but the problem still exist. HELP!
Jan 22, 2006 at 9:56 AM
LOVESCARS
  • 359 POSTS
Could be a bad ground! Have to pay close attention to where the clicking is coming from and reproduce the problem
Was the vehicle equipped with all the bells and whistles rotary lights etc. if so there may still be a flasher relay installed being activated at random
You have some wire chasing time on your hands unless you can locate a mechanic that uninstalls all the emergency equipment to provide you with more specific information.
Jan 22, 2006 at 11:26 AM
Suggested Repair
Check for a bad ground, locate and reproduce the dash click, and inspect for a leftover emergency-equipment flasher relay that may be activating at random. Wiring may need to be traced, ideally by a mechanic experienced with removing police emergency equipment.
Conversation Summary
The owner of a 2003 Ford Police Interceptor says the headlights shut off after a click in the dash while the parking lights stay on, then come back after another click about ten minutes later. This began after an alternator replacement and continued after the dealer installed a new headlight switch. The expert suggests a bad ground, finding the click source, and checking for a leftover emergency flasher relay or related wiring.
