Front End bottoms out 97 T-Bird
1997 FORD
LEONARDO-SF
On a '97 T-Bird, the front end of the car body will scrape the road while driving when it hits a dip in the road. When you check push down on the front end when it's at a stand still, it doesn't bounce but returns to a normal position.
Do the struts or the springs need replacing?
Thanks
Feb 18, 2006 at 6:36 AM
LOVESCARS
  • 359 POSTS
do you have the correct tires on the car
Feb 18, 2006 at 7:57 AM
LEONARDO-SF
Yep. The tires are pretty new (6 months) and I checked the inflation - so tires all good. They are the same size that came with the car.
Feb 23, 2006 at 4:50 PM
LOVESCARS
  • 359 POSTS
consult a steering and suspension tech. Yes it sounds like the springs and the struts are gone if the car is bottoming out
Feb 24, 2006 at 3:41 AM
EPYON2K1
  • 15 POSTS
Hey
The struts and springs should defenitly be chaniged aswell and get the tires allinged and check for proper pressure.
Mar 5, 2006 at 4:53 AM
