Ford Mondeo Service Warning Light
FORD
ANTHONY DEAKIN
how do you turn it off
Jun 5, 2006 at 1:51 AM
LSUSSEL
  • 252 POSTS
For us to be able to assist you, it is absolutely necessary for you to include the make, model, year and mileage of your car
Anyway to turn off a check engine light on most cars the computer inside your car must be reset. have the car checked by a shop to see what comes up. If the engine light comes on then there is a reason for that and something is wrong. you can have the light reset with an engine scanner but I suggest you take it in.
Jun 6, 2006 at 2:09 PM
Suggested Repair
Have the service warning diagnosed at a shop and reset the computer with a scanner only after the underlying fault is identified.
Conversation Summary
The owner of a Ford Mondeo asked how to turn off the service warning light. The expert said the year and mileage were needed and advised against simply clearing the light. The car should be scanned, the fault diagnosed, and the light reset with a scanner after the problem is addressed.
